Jira automation for Epic Creation including Child-Tasks
Marc-Anton Weigelt December 11, 2023
I am struggling with the creation of Jira automation rule:
Trigger: Scheduled date/time
Action: Create Epic
Action: Create Task and link to parent
How do I find / define within the automation rule the parent (name/key/id?) so that I can use it later down the road for linking tasks to it which get created in the same rule?
Preferably without the workaround over branching to get a trigger issue.
Marc
Trudy Claspill
Hello @Marc-Anton Weigelt
After the step where you create the Epic, use the Create Variable action to record the issue key of the new Epic.
https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Create-variable
Then use that variable to set the Parent field in the child story.
Marc-Anton Weigelt December 12, 2023
Thank you, that worked for me perfectly!
Like Trudy Claspill likes this
Rachana Kandlagunta
Hi can I use the same variable set for multiple stories? @Trudy Claspill thank you
Trudy Claspill
Hello @Rachana Kandlagunta
Please start a new Question post and describe your scenario fully. Please provide screen images showing the rule you have created.
