Jira automation prevent duplicate branch creation
Dominick Marino November 14, 2023
I have created an automation rule that creates a branch when a Jira task has been moved to in progress.
In the event that the task is moved back to the assignees TODO to fix a change and the assignee moves it back to their In Progress column again how to prevent the rule from trying to create the same branch again?
Bill Sheboy
November 14, 2023
Hi @Dominick Marino
There are several ways to do this, depending upon your rule structure.
  1. You could set a field, add a label, etc. to indicate the branch has been created.  And the rule could test for the absence of this indicator before proceeding.
  2. You could use the Send Web Request action to call a REST API function in your source control tool, checking if the branch exists before proceeding.
  3. You could use the JQL operator WAS IN and a condition to check if the issue was previously in the status: https://support.atlassian.com/jira-software-cloud/docs/jql-operators/#WAS-IN
The first approach may be easy to try, and to make adjustments as needed.
Dominick Marino November 16, 2023
Ok, thanks. I will give these options a look and see what I can achieve.
Like Bill Sheboy likes this
