I'm looking for a Jira automation rule that creates a JQL filter based on project and last created release, like : project = {{project.name}} and fixversion={{version.name}}
Hi @Tim Van Mierlo you need to set up a automation when a Version is released just send a web request like this:
and then:
Finally you got like this:
I hope it helps
Regards
Additional question : Would it be possible to get the url from this created filter to send it by email?
Well done!!
Additional answer :) You need to enable the "Delay execution of subsequent rule actions until we've received a response for this web request" in the Send request action
then you add send email action:
Finally you got something like this:
@Manuel Bastardo Castellano : I am using the above query as you mentioned but it is still getting error. can you please help.
and moreover, once we create dynamic filter, can we change the filter permissions.
@Abhishek Kalamkar You have a typo in your JSON data in the "Custom data" section of your Web request body.
More specifically,
"name": "{{version.name}} in3 {{version.project.key}}"
should be typed as:
"name": "{{version.name}} in {{version.project.key}}"
Hope this helps fixing your problem!
@Taranjeet Singh In the custom data, that is not typo instead that is text field, we can add any value there. Actually I was getting error that filter already exists so I started using in1, in2 and so on.
