Hi team ,
Jira automation is getting failed can anyone help on this
Hi @bhanu teja
Without seeing the entire webhook data message, it appears you are referencing something that does not exist in the data, or is empty:
{{webhookData.fields.summary}}
I recommend writing just that to the audit log, and then using details of your message to adjust the issue create action.
Was that image from the entire message or what you logged for {{webhookData.fields.summary}}?
If that was the entire message, I do not see "fields" in the message, so try removing that part:
{{webhookData.summary}}
