Jira cloud id, jira client id, jira client secret
Afrothiti Manolis
where do i find these?
Benjamin
Hi @Afrothiti Manolis ,
Thinking you are asking for this info for API calls. This posting may help to retrieve what you need.
This postings should help you to get what you need:
https://community.atlassian.com/t5/Jira-discussions/What-is-my-cloud-id/td-p/900091
https://community.atlassian.com/t5/Jira-questions/How-to-Authenticate-Jira-Rest-APIs-using-Client-ID-and-Client/qaq-p/1546410
-Ben
Afrothiti Manolis
The simplest way to find your site's Cloud Id is via: https://my-site-name.atlassian.net/_edge/tenant_info
Which, when you replace "my-site-name" with your Jira's site name, will return the following
{"cloudId":"93ac17d7-fe07-4ba3-a53c-5caeb380fff8"}
 This is really poorly documented, and the only mention I saw of it was a one liner on the new Forms API docs
^^was the only helpful comment i saw earlier- thanks!
Like # people like this
kristen.shryack
December 6, 2024
This worked for me. Thanks!
Trudy Claspill
Hello @Afrothiti Manolis
In what context are you being asked to provide the information?
Is there some document you are referencing that directs you to get those items? Is that a document for which you can share the link?
Afrothiti Manolis
github <> jira integration
