Hi @Stu,
Just to confirm your request; you want to know if you can associate the create issue and edit issue schemes with the same screen? If this is correct you should be able to.
Have I misunderstood the request?
Hope this helps.
I believe that is right - just to clarify...
If I'm looking at my issues on a Kanban board, and I create an issue or edit an issue, the screen is the same, which is the more detailed view.
Thanks for your help
