Jira error can't tell which database using
vivekrao_k
Hi Everyone,
we have recently upgrade our Jira instance from 8.13 to 8.20 everything went well and in last we are getting below error. although there is an option to ignore and continue, we would like to know what is causing this error. attaching a snip for reference
Mayur Jadhav
Hello @vivekrao_k .
Hope you are doing well!!
As from the screenshot, Your database version is not compatible with your Jira version. Either upgrade your Jira or Database to be compatible.
As of now you can click Ignore all warning and Continue.
Mayur
vivekrao_k
Hi Mayur,
Thank you for the response. i am using Jira 8.20.11 and mysql 8.0.21 and according to atlassian document it is supportive version.
vivek
Mayur Jadhav
@vivekrao_k , I have just checked 8.20.11 is compatible with 8.0 version. I would suggest your open support ticket with Atlassian to check.
vivekrao_k
Just now raised, lets see what would be the solution
Like Mayur Jadhav likes this
vivekrao_k
Hi @Mayur Jadhav
Found solution for this. there are 2 points
1. after home data redirection i was using same old db.config from APP DATA this needs to be modified with the new db.config (the one which we received for fresh installation of new version)
2. changed the mysql data type from UTF8 to UTF8mb4
vivek
Mayur Jadhav
@vivekrao_k Glad the issue is resolved finally
