Jira field values removal
Bindu Shrivastav August 18, 2021
Hi Team,
Our project now has transitioned to maintenance mode.  During initial project development phase people created too many fixVersion values.
Many of these values are not needed and not applicable.
But in backlog, too many fixVersion show up even though there are no issues assigned that value, cluttering the view.
Is there a way to remove those value options from the fix version field?
Thank you so much in advance,
Bindu Shrivastav
Ismael Jimoh
August 18, 2021
Delete them from the versions page in project settings @Bindu Shrivastav
That automatically removes them.
Bindu Shrivastav August 19, 2021
Hi Ismael,
This is about removing values, not fields, Right?
I dont see version page under Project Setting see below.
Bindu Shrivastav August 20, 2021
Isamael,
Thank you .  I found that Versions are listed and can be edited from Summary option.
Project setting-> Summary then, under 'Versions' section click 'Show all'
This gives option to edit/delete.
Bindu
