I'm using Mac.I tried everything including increasing timeout and memory.But nothing works.I'm using openjdk 1.8
I'm getting this error from localhost
We couldn't start the following plugins:
Hi @M By ,
The issue is discussed here https://community.atlassian.com/t5/Jira-questions/jira-startup-failed/qaq-p/1215226
JiraHome is a path and not the name of the directory. It may vary depending on your installations.
I found two different installations online.One is like starting tomcat with sh startup.sh and if I do that I have to create a folder called JiraHome and the website comes with localhost:8080 and it shows Jira Software not Jira.
If I install it like the way in hello world plugin in Atlassian docs then I don't have any jirahome and the page comes in localhost:2990 and it says the errors up there.
How can I install it so that it says Jira not Jira Software.I'm using Mac
