Jira installation directory: Path and naming conventions
Frank Werhan July 13, 2018
are the following assumptions correct?
  • Jira application installation directory = Jira installation directory
  • Jira installation directory =  C:\Program Files\Atlassian\Application Data\JIRA (default path using the windows installer)
The article
https://confluence.atlassian.com/adminjiraserver/jira-application-installation-directory-938847745.html
confuses me a little bit.
Thank you for your help in advance.
Best regards
Frank Werhan
Andy Heinzer
July 16, 2018
Hi Frank,
The first point is correct, however the second point is not.   Jira will make use to two different directories:
  1. The Jira installation directory
  2. And the Jira Home directory
In this case, the installation directory is where Jira is installed as an application, (and where the startup files are).   However your specific Jira data like user plugins, attachments, avatars, indexes, etc, are all stored in the Jira Home directory.   In this case, the C:\Program Files\Atlassian\Application Data\JIRA is a default path to keep the $JIRAHOME directory on a windows environment.
Frank Werhan July 18, 2018
Hi Andrew,
Thank you for your reply. There is a mistake in my assumption. I wanted to write the following:
  • Jira installation directory = C:\Program Files\Atlassian\JIRA (default path using the windows installer)
That's correct, isn't it?
Best Regards,
Frank Werhan
Andy Heinzer
July 18, 2018
Yes, Frank, I believe that is the default path for the installation directory of Jira in Windows.
Hi Andrew,
Thank you.
Best Regards
Frank Werhan
