are the following assumptions correct?
The article
confuses me a little bit.
Thank you for your help in advance.
Best regards
Frank Werhan
Hi Frank,
The first point is correct, however the second point is not. Jira will make use to two different directories:
In this case, the installation directory is where Jira is installed as an application, (and where the startup files are). However your specific Jira data like user plugins, attachments, avatars, indexes, etc, are all stored in the Jira Home directory. In this case, the C:\Program Files\Atlassian\Application Data\JIRA is a default path to keep the $JIRAHOME directory on a windows environment.
Hi Andrew,
Thank you for your reply. There is a mistake in my assumption. I wanted to write the following:
That's correct, isn't it?
Best Regards,
Frank Werhan
Yes, Frank, I believe that is the default path for the installation directory of Jira in Windows.
