Jira issue while starting up after importing self signed Certificate
Jorge Trujillo March 19, 2019
Change: Created and upload a self signed certificate into Jira to enable HTTPS
i now get the following error
Setup: Tomcat is misconfigured
The server.xml file is missing parameters needed by Jira to handle requests that contain special characters.
I followed the link
https://confluence.atlassian.com/jirakb/changing-server-xml-to-handle-requests-with-special-characters-958453799.html
This solution is already in the server-xml file
Jakub Sławiński
March 20, 2019
Have you updated all the connectors?
Jorge Trujillo March 20, 2019
Thanks,  I am pretty sure I updated the file and its connectors. I could be wrong never done this before. Attaching the contents of the file maybe you can point out if I did something wrong.
<?xml version="1.0" encoding="UTF-8"?><!--
Licensed to the Apache Software Foundation (ASF) under one or more
contributor license agreements. See the NOTICE file distributed with
this work for additional information regarding copyright ownership.
The ASF licenses this file to You under the Apache License, Version 2.0
(the "License"); you may not use this file except in compliance with
the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
--><Server port="8005" shutdown="SHUTDOWN">
<Listener className="org.apache.catalina.startup.VersionLoggerListener"/>
<Listener SSLEngine="on" className="org.apache.catalina.core.AprLifecycleListener"/>
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener"/>
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/>
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener"/>
<Service name="Catalina">
DEFAULT - Direct connector with no proxy for unproxied access to Jira.
If using a http/https proxy, comment out this connector.
<!-- Relaxing chars because of JRASERVER-67974 -->
<Connector acceptCount="100" bindOnInit="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" port="8080" protocol="HTTP/1.1" redirectPort="8443" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^&#x5c;&#x60;&quot;&lt;&gt;" useBodyEncodingForURI="true"/>
HTTP - Proxying Jira via Apache or Nginx over HTTP
If you're proxying traffic to Jira over HTTP, uncomment the below connector and comment out the others.
Ensure the proxyName and proxyPort are updated with the appropriate information if necessary as per the docs.
See the following for more information:
Apache - https://confluence.atlassian.com/x/4xQLM
nginx - https://confluence.atlassian.com/x/DAFmGQ
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^&#x5c;&#x60;&quot;&lt;&gt;"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="<subdomain>.<domain>.com" proxyPort="80"/>
HTTPS - Proxying Jira via Apache or Nginx over HTTPS
If you're proxying traffic to Jira over HTTPS, uncomment the below connector and comment out the others.
Apache - https://confluence.atlassian.com/x/PTT3MQ
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="<subdomain>.<domain>.com" proxyPort="443"/>
AJP - Proxying Jira via Apache over HTTP or HTTPS
If you're proxying traffic to Jira using the AJP protocol, uncomment the following connector line
Apache - https://confluence.atlassian.com/x/QiJ9MQ
<Connector port="8009" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^&#x5c;&#x60;&quot;&lt;&gt;"
URIEncoding="UTF-8" enableLookups="false" protocol="AJP/1.3"/>
<Engine defaultHost="localhost" name="Catalina">
<Host appBase="webapps" autoDeploy="true" name="localhost" unpackWARs="true">
<Context docBase="${catalina.home}/atlassian-jira" path="" reloadable="false" useHttpOnly="true">
<Resource auth="Container" factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60" name="UserTransaction" type="javax.transaction.UserTransaction"/>
<Manager pathname=""/>
<JarScanner scanManifest="false"/>
</Context>
</Host>
<Valve className="org.apache.catalina.valves.AccessLogValve" pattern="%a %{jira.request.id}r %{jira.request.username}r %t &quot;%m %U%q %H&quot; %s %b %D &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; &quot;%{jira.request.assession.id}r&quot;"/>
</Engine>
<Connector relaxedPathChars="[]|" relaxedQueryChars="[]|{}^&#x5c;&#x60;&quot;&lt;&gt;" SSLEnabled="true" acceptCount="100" clientAuth="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" keyAlias="JiraIS" keystoreFile="C:\Program Files\Atlassian\JIRA\JiraIS" keystorePass="passwordichanged" keystoreType="JKS" maxHttpHeaderSize="8192" maxSpareThreads="75" maxThreads="150" minSpareThreads="25" port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol" scheme="https" secure="true" sslProtocol="TLS" useBodyEncodingForURI="true"/></Service>
</Server>
Jakub Sławiński
March 21, 2019
You used invalid path.
Instead of
you should use something like this:
keystoreFile="C:/Program Files/Atlassian/JIRA/JiraIS"
Like # people like this
Jorge Trujillo March 22, 2019
Thank you yes that help resolved my issue
brbojorque
Hi @Jorge Trujillo , it looks like you have an issue with special characters in the Connector tag.
Double check the value of the string and make sure there is no missing " or possibly escape the special chars.
Thanks for the update I am pretty sure I update the file and its not missing anything could be wrong never done this before. Attaching the contents of the file maybe you can point out if i did something wrong.
</Context>
</Host>
</Engine>
</Server>
