Hello.I make a plugin with jira-rest-java-client-core.I have some problems with dependencies.
Version jira:
8.13.10
My pom file:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>ru.alfabank.atlassian</groupId>
<artifactId>jira-vendor-sync</artifactId>
<version>1.0.0</version>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<name>jira-vendor-sync</name>
<description>This is the ru.alfabank.atlassian:jira-vendor-sync plugin for Atlassian JIRA.</description>
<packaging>atlassian-plugin</packaging>
<repositories>
<repository>
<id>alfa-public</id>
<name>public Repository</name>
<url>https://binary.alfabank.ru/artifactory/public</url>
<layout>default</layout>
<snapshots>
<enabled>false</enabled>
</snapshots>
</repository>
<repository>
<id>alfa-central</id>
<name>Central Repository</name>
<url>https://binary.alfabank.ru/artifactory/mavenatlassian</url>
<snapshots>
</snapshots>
</repository>
</repositories>
<pluginRepositories>
<pluginRepository>
<id>atlassian-plugin-sdk-public</id>
<releases>
<enabled>true</enabled>
<checksumPolicy>warn</checksumPolicy>
</releases>
<snapshots>
</snapshots>
</pluginRepository>
<pluginRepository>
<id>atlassian-plugin-sdk</id>
<name>Central plugin Repository</name>
<releases>
</releases>
<snapshots>
</snapshots>
</pluginRepository>
</pluginRepositories>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
<exclusions>
<exclusion>
<groupId>io.atlassian.util.concurrent</groupId>
<artifactId>atlassian-util-concurrent</artifactId>
</exclusion>
<exclusion>
<groupId>com.atlassian.httpclient</groupId>
<artifactId>atlassian-httpclient-library</artifactId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>com.atlassian.templaterenderer</groupId>
<artifactId>atlassian-template-renderer-api</artifactId>
<version>4.1.4</version>
</dependency>
<dependency>
<groupId>org.projectlombok</groupId>
<artifactId>lombok</artifactId>
<version>1.18.22</version>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<dependency>
<artifactId>jira-rest-java-client-core</artifactId>
<version>5.1.2-2bd0a62e</version>
JIRA will already provide a number of dependencies that JRJC needs. We need to exclude
them from the JRJC dependency as we don't want to package them up inside the plugin.
<exclusions>
<exclusion>
<groupId>com.sun.jersey</groupId>
<artifactId>jersey-client</artifactId>
</exclusion>
<exclusion>
<artifactId>jersey-json</artifactId>
</exclusion>
<exclusion>
<groupId>joda-time</groupId>
<artifactId>joda-time</artifactId>
</exclusion>
<exclusion>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
</exclusion>
<exclusion>
<groupId>com.atlassian.event</groupId>
<artifactId>atlassian-event</artifactId>
</exclusion>
<exclusion>
<groupId>org.springframework</groupId>
<artifactId>spring-beans</artifactId>
</exclusion>
<exclusion>
<groupId>org.apache.commons</groupId>
<artifactId>commons-lang3</artifactId>
</exclusion>
<exclusion>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>servlet-api</artifactId>
<version>2.4</version>
</dependency>
<dependency>
<version>1.6.6</version>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>jira-maven-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<!-- Uncomment to install TestKit backdoor in JIRA. -->
<pluginArtifacts>
<pluginArtifact>
<groupId>com.atlassian.jira.tests</groupId>
<artifactId>jira-testkit-plugin</artifactId>
<version>${testkit.version}</version>
</pluginArtifact>
</pluginArtifacts>
<enableQuickReload>true</enableQuickReload>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package import here -->
<!--<Import-Package>org.springframework.osgi.*;resolution:="optional", org.eclipse.gemini.blueprint.*;resolution:="optional", *;version="0";resolution:=optional</Import-Package>-->
<Import-Package>
com.atlassian.inject;resolution:="optional",
com.sun.xml.fastinfoset.*;resolution:="optional",
groovy.*;resolution:="optional",
joptsimple;resolution:="optional",
net.sf.ehcache;resolution:="optional",
net.spy.memcached;resolution:="optional",
org.*;resolution:="optional",
sun.misc;resolution:="optional",
</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>8.13.10</jira.version>
<amps.version>8.1.2</amps.version>
<plugin.testrunner.version>2.0.2</plugin.testrunner.version>
<atlassian.spring.scanner.version>2.1.7</atlassian.spring.scanner.version>
<!-- This property ensures consistency between the key in atlassian-plugin.xml and the OSGi bundle's key. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
</project>
And i have error with compilation:
[WARNING] Rule 0: org.apache.maven.plugins.enforcer.BannedDependencies failed with message:
make sure platform artifacts are not bundled into plugin
Found Banned Dependency: io.atlassian.util.concurrent:atlassian-util-concurrent:jar:4.0.1
Found Banned Dependency: com.google.code.findbugs:jsr305:jar:3.0.2
Found Banned Dependency: com.google.guava:guava:jar:26.0-jre
Found Banned Dependency: com.atlassian.httpclient:atlassian-httpclient-api:jar:2.0.0
Found Banned Dependency: org.apache.httpcomponents:httpcore:jar:4.4.10
Found Banned Dependency: org.apache.httpcomponents:httpmime:jar:4.5.5
Found Banned Dependency: org.apache.httpcomponents:httpclient:jar:4.5.5
Found Banned Dependency: org.apache.httpcomponents:httpclient-cache:jar:4.5.5
Use 'mvn dependency:tree' to locate the source of the banned dependencies.
That means external httpcomponents are banned by jira for some reason, either because its already shipped with one and you need scope provided(which you say result in classNotFound error) OR its blocked on some other level. Anyways, you'd need to switch to another package to do http requests if thats the case.
Hope it helps.
You can try to set the version of AMPS back to 8.0.0 and package the app again.
<amps.version>8.0.0</amps.version>
Hello @vovkakibe
Try adding <scope>provided</scope> for those dependencies which means that Maven will not package those dependencies, and the container will provide them.
Hope it helps
Tuncay
If i add this dependencies to scope provided i have another problem:
java.lang.NoClassDefFoundError: org/codehaus/jettison/json/JSONException
After i add new dependencies to my pom:
<!-- https://mvnrepository.com/artifact/org.codehaus.jettison/jettison -->
<dependency>
<groupId>org.codehaus.jettison</groupId>
<artifactId>jettison</artifactId>
<version>1.4.1</version>
</dependency>
And get this:
java.lang.NoSuchMethodError: com.atlassian.httpclient.api.ResponseTransformation$Builder.ok(Lcom/google/common/base/Function;)Lcom/atlassian/httpclient/api/ResponseTransformation$Builder;
Yes, but it is good to have fewer dependencies in the jar file, so adding all runtime dependencies (with provided scope) would be better IMO.
