Jira loading problem
anjitha_s June 2, 2021
Currently we are facing much delay in the loading of Jira pages. Not only from the user part, but the Jira admin side also takes too long to respond.
Recently, we have deployed some plugins as well.
Anyone could sort out what exactly the issue is.
Anjitha
Daniel Ebers
June 6, 2021
Hi @anjitha_s
next to the perfect information from Niranjan you also could have a study of the troubleshooting guide for performance issues:
https://confluence.atlassian.com/jirakb/troubleshoot-performance-issues-in-jira-server-336169888.html
It is nearly impossible to pinpoint a specific cause here from Community, it will need support from your system administrator. However, the five bullet points of Niranjan can give a first idea on where to start.
The troubleshooting guide discusses them even more detailed, so it might make sense to have a deeper look.
Daniel
anjitha_s June 7, 2021
Thank you Daniel
Niranjan
June 2, 2021
Hi @anjitha_s ,
I would need more information about the issue to be more specific with my answers.
1. Try disabling the recently installed plugins and monitor the application load times.
2. Check if there are any heap dumps generated.
3. Check the atlassian-jira.log for any OutOfMemory error.
4. You may need to check for the RAM on your server and increase it as required.
5. Also consider increase JVM parameters- max and min memory in setenv.sh file
Thank you Niranjan
