Hi y'all,
I am seeing strange behavior of the dark mode setting in two of my jira sites.
When I open Jira, the page loads in dark mode but then immediately switches and reloads in light mode. I have to send the ctrl-k switch theme command to go back into dark mode, or adjust the mode in my settings. Changing pages within Jira or refreshing the page will sometimes also cause this behavior.
I have my default color set to dark mode. Chrome is also set to dark mode, as is windows.
Anyone experience a similar issue?
@Thomas K. Ganss welcome to the Atlassian community
Is it happening in all browsers? Is it happening to other users? Have you tried clearing your cache?
Thanks for your response!
@Thomas K. Ganss what happens if you use incognito mode in chrome? I am wondering if it has something to do with your settings when you are logged into chrome.
That seems to make a difference, actually. It seems to behave correctly while I'm in incognito.
Any ideas where to look for the right chrome setting?
@Thomas K. Ganss usually it has something to do with cache. When you cleared cache did you clear it for all time and everything was checked. Your logged in profile will have cache specifically associated with it.
I think I've chased it to a utility extension I had running. Removing it from my browser seems to have solved it. Thanks for pointing me in the incognito direction--that led me to checking my extensions.
