Jira plugins importer class ExternalProject has a method which returns a null value
Aditya Sharma June 30, 2020
com.atlassian.jira.plugins.importer.external.beans.ExternalProject
Using the above Class method called getIssues()- I am trying to access the existing issues in my local jira instance but it returns a null value even if the project has Issues.  What can be the possible issue?
I am getting the following error:
[INFO] [talledLocalContainer] 2020-07-01 03:06:05,752 JiraTaskExectionThread-5 INFO admin 185x22132x1 1lfm2tj 0:0:0:0:0:0:0:1 /secure/admin/ImporterLogsPage%21import.jspa [c.a.j.p.i.i.importer.impl.AbstractDataImporter$1Thread[http-nio-2990-exec-10,5,main]] Only new items will be imported
[INFO] [talledLocalContainer] External ProjectExternalProject{id='null', key='XTP', externalName='project', name='XYZ Test Project'}
[INFO] [talledLocalContainer] exisiting issuesnull
[INFO] [talledLocalContainer] 2020-07-01 03:06:05,757 JiraTaskExectionThread-5 INFO admin 185x22132x1 1lfm2tj 0:0:0:0:0:0:0:1 /secure/admin/ImporterLogsPage%21import.jspa [c.a.j.p.i.i.importer.impl.AbstractDataImporter$1Thread[http-nio-2990-exec-10,5,main]] ------------------------------
[INFO] [talledLocalContainer] 2020-07-01 03:06:05,757 JiraTaskExectionThread-5 INFO admin 185x22132x1 1lfm2tj 0:0:0:0:0:0:0:1 /secure/admin/ImporterLogsPage%21import.jspa [c.a.j.p.i.i.importer.impl.AbstractDataImporter$1Thread[http-nio-2990-exec-10,5,main]] Finished Importing : Issues
[INFO] [talledLocalContainer] 2020-07-01 03:06:06,496 JiraTaskExectionThread-5 INFO admin 185x22132x1 1lfm2tj 0:0:0:0:0:0:0:1 /secure/admin/ImporterLogsPage%21import.jspa [c.a.j.p.i.i.importer.impl.AbstractDataImporter$1Thread[http-nio-2990-exec-10,5,main]] ------------------------------
[INFO] [talledLocalContainer] 2020-07-01 03:06:06,496 JiraTaskExectionThread-5 ERROR admin 185x22132x1 1lfm2tj 0:0:0:0:0:0:0:1 /secure/admin/ImporterLogsPage%21import.jspa [c.a.j.p.i.i.importer.impl.AbstractDataImporter$1Thread[http-nio-2990-exec-10,5,main]] Unexpected failure occurred. Importer will stop immediately. Data may be in an unstable state
[INFO] [talledLocalContainer] java.lang.NullPointerException
[INFO] [talledLocalContainer] at com.tadigital.jira.plugin.TACsvDataBean$2.apply(TACsvDataBean.java:99)
[INFO] [talledLocalContainer] at com.tadigital.jira.plugin.TACsvDataBean$2.apply(TACsvDataBean.java:1)
Here is the code snippet of data bean class :
@Override
public Set<ExternalProject> getAllProjects(ImportLogger log) {
final ExternalProject project = new ExternalProject(configBean.getProjectName("project"),
configBean.getProjectKey("project"));
project.setExternalName("project");
return Sets.newHashSet(project);
@Override
public Iterator<ExternalIssue> getIssuesIterator(ExternalProject externalProject, ImportLogger importLogger) {
return Iterables.transform(csvClient.getInternalIssues(), new Function<Issue, ExternalIssue>() {
@Override
public ExternalIssue apply(Issue from) {
final ExternalIssue externalIssue = new ExternalIssue();
List<ExternalIssue> getExistingIssues = externalProject.getIssues();
return externalIssue;
}).iterator();
Dario B
July 2, 2020
Hello @Aditya Sharma ,
Please notice that this is not the best place to get help on development related topics.
In case of no answer in here please refer to the resources listed in: https://developer.atlassian.com/resources.
Specifically:
Dario
Aditya Sharma July 2, 2020
Hi @Dario B
I will surely keep that in mind. Actually I am new to Jira and Jira related development. I usually don't approach like this but I was really stuck. Anyway, thanks for the heads up. I will refer to the links you have mentioned.
Happy learning!
Thanks and Regards,
Aditya
Like Dario B likes this
Dario B
July 3, 2020
You are very welcome @Aditya Sharma . Good luck with your project! :)
FREE
