I have a ticket with the customfield_10448 set to: Production
And then an automation rule having an action trying to set another field depending on the comparison of this field's value with a string:
Environment : {{issue.customfield_10448.value}}
{{#if(equals(issue.customfield_10448.value, "Production"))}}
MEP
Can someone explain me why this code only output that:
Environment : Production
and not this:
MEP
Of course, a hint at how to fix it will be much appreciated!
Some things to check for this symptom would be:
Well, I went around by using a "Create variable" action, naming it envSV and assigning it {{issue.customfield_10448.value}}.
Then the modified code worked:
{{#if(equals(envSV, "Production"))}}
MEP
Output : MEP
Looks like some review of Jira smart values for conditional logic should be done by developers.
And I'm not talking only about the poor documentation...
And of course, as it's only a workaround, I can't deem this answer acceptable ;-)
Hi @Jérôme RAVIER ,
is it required to use the advanced (json) here? Can you not just use the If/else condition?
