After migrating the data from Jira cloud to Jira server, we have observed that for issuetype = 'subtask', the description field is giving below error message.
Kindly provide me your valuable suggestions
An error occurred whilst rendering this message. Please contact the administrators, and inform them of this bug. Details: ------- org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getHtml' in class com.atlassian.jira.web.component.subtask.SubTaskSequenceColumnLayoutItem threw exception java.lang.NullPointerException: null value in entry: actualSequence=null at templates/jira/issue/table/macros.vm[line 117, column 34] at org.apache.velocity.runtime.parser.node.ASTMethod.handleInvocationException(ASTMethod.java:342) at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:284) at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:262) at org.apache.velocity.runtime.parser.node.ASTReference.value(ASTReference.java:507) at org.apache.velocity.runtime.parser.node.ASTExpression.value(ASTExpression.java:71) at org.apache.velocity.runtime.parser.node.ASTSetDirective.render(ASTSetDirective.java:142) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:72) at org.apache.velocity.runtime.directive.Foreach.performIteration(Foreach.java:393) at org.apache.velocity.runtime.directive.Foreach.render(Foreach.java:316) at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:175) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:72) at org.apache.velocity.runtime.directive.VelocimacroProxy.render(VelocimacroProxy.java:212) at org.apache.velocity.runtime.directive.RuntimeMacro.render(RuntimeMacro.java:247) at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:175) at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:72) at org.apache.velocity.runtime
I solved the problem like this.
Atlassian recommended with the below solution which apparently fixed the issue. Please try it out from your end.
I have checked the information you provided and it appears that there is an inconsistency in your database. Thank you for letting us know that you already ran the integrity checker and performed a re-index.
Currently the issue looks to be related to the issuelink table, can you please take the following steps?
2. 3. select count(*) from jiradb.issuelink where sequence IS NULL;
5. 6. select * from jiradb.issuelink where sequence IS NULL;
8. UPDATE issuelink SET sequence = 0 WHERE linktype=10100 AND sequence IS NULL;
@Вячеслав Калашников Welcome to the Atlassian community
Looks like you have some broken data somewhere after doing your migration. I would suggest:
If you are still having the issue afterwards you will need to review more of the logs to see if you can determine what the issue is.
Hi. thanks for your answer. integrity checker and full re-index did not help me
I would suggest submitting a support issue to Atlassian but I would also try disabling the add-ons that are not in the server instance, creating a new export and seeing if that fixes the issue.
