×Hi community!
I want to send all traffic to /jira/rest to a specific Jira node/ pod. I succeeded but when I login onto the UI and navigate to another page within Jira I am logged out again. I assume it is realted because of the following:
This related articles mentions:
Configure the load balancer to only direct REST API traffic with the following conditions:
- Referred externally from the application
- Not requesting the login page
I did not configure those conditions yet. Does anyone know how to do it in an nginx ingress rule?
I am in no way an expert in Jira but I guess if I had to solve such a problem with Nginx ingress controller I'd:
* create a new service which uses a unique label (pods in the statefulset will have it)
* add another path to your spec.rules.http.paths and use your new service as a backend
Also there's a general requirement to make sure you have session affinity (sticky cookies) enabled for your ingress.
Thanks for your answer.
What you describe is exactly what I did and session affinity is also configured.
The routing for /jira/rest works. It always goes to my jira-0 pod. But it causes issues in the UI. Probably because I did not set the 2 conditions.
As a workaround we will use a dedicated hostname for the API.
