This instance of Jira was flagged by Nessus as needing to be updated to remediate a potential vulnerability. I went through the upgrade preliminary steps (backups, etc.) then downloaded the 8.19.0 bin file and ran it. After the update, when I run "service jira start", it seems to start, but when I try to log into Jira itself, it complains about "error in MySQL supported version".
I've tried changing the "default_storage_engine" to mysql57 with no success. I reverted it back to InnoDB, still with no success. I don't know what else to do.
The database (MySQL 5.7.31) is on an AWS RDS instance. The Jira host is running on Ubuntu 16.04.7 LTS
It's not feasible to roll back to 8.15.0, as Jira complains about a data version mismatch.
HI @Andrew Howey , it is always good idea to check a atlassian-jira.log file. Did you check it? Can you share what errors/exceptions occured?
@Martin Bayer _MoroSystems_ s_r_o__ -- This is what I see in the atlassian-jira.log:
FWIW, our database is hosted on an AWS RDS instance. I can connect to it from the command line.
Here is the version information as given by the database itself:
(jira@govcloud-jira-rds.cyx8nrstcyts.us-gov-west-1.rds.amazonaws.com) [govcloud_jira]> show variables like '%version%';
| Variable_name | Value |
| innodb_version | 5.7.31 |
| protocol_version | 10 |
| slave_type_conversions | |
| tls_version | TLSv1,TLSv1.1,TLSv1.2 |
| version | 5.7.31-log |
| version_comment | Source distribution |
| version_compile_machine | x86_64 |
| version_compile_os | Linux |
And here is the database connect string from the dbconfig.xml:
<url>jdbc:mysql://govcloud-jira-rds.cyx8nrstcyts.us-gov-west-1.rds.amazonaws.com:3306/govcloud_jira?useUnicode=true&characterEncoding=UTF8&sessionVariables=default_storage_engine=InnoDB</url>
Hi @Andrew Howey you also need to use correct driver's version. Can you check against supported platforms page for your version?
https://confluence.atlassian.com/adminjiraserver/supported-platforms-938846830.html
Hi, @Martin Bayer _MoroSystems_ s_r_o__ -- The driver listed for Ubuntu (Connector/J 8.0.26) is for 18.04, 20.04, and 21.04. My jira server is running on 16.04. Can I use one of the drivers listed for 18.04? If so, which one would be appropriate?
This is my OS information;
I'd try to use platform independent release 5.1.49
https://downloads.mysql.com/archives/get/p/3/file/mysql-connector-java-5.1.49.tar.gz
I have the same issue
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.5 LTS
Release: 18.04
Codename: bionic
I tried the .48 and .49-bin.jar driver but it just wont connect and does not give any useful information in the logs.
SO post: https://serverfault.com/questions/1076510/jira-upgrade-8-19-0-cannot-connect-to-mysql-5-7-35
Rolling back to jira 8.16.0
Since my database is hosted on an AWS RDS instance, I was able to restore the most recent snapshot and roll back to 8.15.0 that way.
I'll have to revisit the upgrade to 8.19.0 after some consideration and planning.
Thanks @Martin Bayer _MoroSystems_ s_r_o__ for all your suggestions. :)
8.19.0 introduced a new version of Java which caused a set of command line option errors. Have you checked the catalina.out log for the setup logs? If the issue is from the java update, it will reference encountering the unknown arguments in that log file. Then you have two options: ignoring those arguments by adjusting your setenv.sh file for the startup arguments (that's on the last line of the file), or you can update your java version.
Take a look at https://confluence.atlassian.com/jirakb/change-the-java-version-used-by-jira-server-765594330.html
