Kanban approach + Scrum approach under same Project
Prasanna subramaniam
Dear Community,
I am planning to consolidate everything under a single project. Is this feasible in the Atlassian JIRA Premium version?
  • Kanban approach: EPIC and Feature (with customized lanes)
  • Scrum approach: For stories
I have successfully implemented this in Azure ADO, and my business stakeholders easily adapted to the new workflow. I want to confirm if this is possible in JIRA as well.
Thank you !
Prasanna Subramaniam
John Funk
Hi Prasanna,
Yes, you can certainly do that. But sure to use a Company-managed project thought, and not Team-managed.
Dear @John Funk ,
Thank you for your response.
I am unable to create a Kanban board for EPIC and Feature in a company-managed project. I'm not sure where I might be going wrong.
Could you please provide more details to help me? I apologize for any inconvenience.
Thank you for your support!
Like John Funk likes this
John Funk
How are you trying to do it? You should be able to click in the site Search box in the upper right of the top nav bar. Then scroll down to Boards at the bottom and click on that link.
There you can create a new board.
Like Prasanna subramaniam likes this
Dear @John Funk ,
Got it :) . Thanks you !
John Funk
You are welcome! If this solved it for you, please click the Accept Answer button above. Thanks!
FREE
