Keep all values when migrating issues
Jagmohan
Hi all,
When I want to migrate an issue between two software projects, many values are deleted. There is no way to map these fields in the "Move issue" wizard.
We work with sprints in project 1 while the other project is kanban. I've created the same fields in the kanban project which are in the sprint project (see image)
But when I'm moving the issue, the values are not mapped.
Where do I map these fields between projects?
Curious to know
Kian Stack Mumo Systems
@Jagmohan
Is there any context set on these custom fields limiting them to a specific project and.or issue types?
Kian
Jagmohan
Hi @Kian Stack Mumo Systems
The custom fields I want to migrate were created in the first project (sprint structure). Then we created a second project (kanban style). When moving stories, these fields would lose the values because there were no fields to map to in the kanban project. I could not select the sprint project custom fields in the kanban project.
So I created new fields identical to the ones in the sprint project, but there is no way to map them. As far as I know, they are not limited to a project as I can select the new fields in the sprint project as well. Also: the newly created fields are available in the Custom Fields screen, but not the old sprint project related fields.
See images below
Hope this provides more context and thanks for your help <3
@Jagmohan
Yes, this does.
The issue is that you are trying to move issues from a Team Managed project to a company managed project.
Team managed custom fields are completely unique from the custom fields you've created for your Kanban project. As such the values won't transfer.
Please review this documentation for information on migrating team managed -> company managed.
Like Jagmohan likes this
Jagmohan
Thanks for the reference documentation @Kian Stack Mumo Systems - that explains a lot. Now the next step (:
I read the following:
Custom fields: If you use custom fields in your team-managed project, a Jira admin needs to recreate the fields and add them to screen schemes and field configurations in your company-managed project. Custom field data will need to be recreated, otherwise it will be lost.
Okay: the fields have been created and added to the screens. I don't understand what is meant by "Custom field data will need to be recreated" or how to do it.
Back to my original question: is it possible to map those fields between team-managed > company-managed projects?
No. You would need to export your issues from your Team managed project first. Then move the tickets to the new project, and then reimport those values using a csv import.
