Keeping Custom Field Values in Sync Between Parent and Child Issues Using Automation for Jira
Josef Sigl November 18, 2024
Hi all, i want to compare values of a custom field in parent and child issue.
With this Instructions it works nearly perfect =>
https://confluence.atlassian.com/jirakb/keeping-custom-field-values-in-sync-between-parent-and-child-issues-using-automation-for-jira-1318881724.html
But if i change 2 or more values in this field, the values of the child-Issue will be erased.
The Change works only with 1 value
regards
Josef
Marc - Devoteam
November 18, 2024
Hi @Josef Sigl
Please share the details on your created rule, with step details and also with the audit log failure details.
What type of custom fields are you using, share details.
All this information will help community members to assist you with your current request.
Hi all,
the config of the field
the automation rule
There is no error log, because it work perfectly if change only one value.
It don't work if change more than 1 value. Then the Automation rule clear all values of the CHILD issues.
Regards
Josef
Marc - Devoteam
November 19, 2024
Hi @Josef Sigl
Do change the values on the Epic or on the Child?
I think my example is simpler, if you make the changes on the Epic side:
Like Josef Sigl likes this
Josef Sigl November 19, 2024
Hi Marc, thanks a lot! It works!!
Now I fill the values at "Issue create" and "Parent Issue edit" and ut works perfektly.
The last thing that i've to do now is, filling the field in Child, if the field in child is empty, but the value in field of parent Issue is not EMPTY.
Can you help me again there?
Thank
Regards
Josef
Marc - Devoteam
November 19, 2024
Hi @Josef Sigl
What actions do you want to take;
  1. have the parent still overwrite the child?
  2. add the child option to the parent?
  3. add the child option to the parent and the parent options to the child?
Josef Sigl November 20, 2024
Hi Marc,
I only need one way. From Parent to child.
I need to transfer these values ​​once from the parent issue to the child issue.
currently there are many child Issues wich the field value is currently empty and i have to fill this.
Regards
Marc - Devoteam
November 20, 2024
Hi @Josef Sigl
Copy the Rule I provided and change the trigger, Use a manual trigger.
Then you are able to run that rule on every issue, via the action button, the action it will do is copy the current options from Epic to the children.
Or create a rule as follows, runs this one and then remove it. This rule will find all Epic based on a JQL in the scheduled trigger and then for each found Epic action on the child issues.
Josef Sigl November 21, 2024
Hi Marc,
thank you very much for your help. It works too ;-)
regards
Josef
SERVER
