Key search does not work
Natalia Soikko January 29, 2019
Hi all,
Do you have any idea why search:
project = XXX and key > xxx-123 and key <xxx-333
does not work anymore? This search was working 4 days ago :(
We are using JIRA 7.6
Ollie Guan
Hi @Natalia Soikko,
Can you remove the previous conditions for querying the project and use the latter half to find out the results?
 key > xxx-123 AND  key < xxx-333
Hi @Ollie Guan
I just have found the reason for search failure.
The issue with key xxx-333 has been deleted from JIRA. So query fails because of that.
I have changed query to "project = XXX and key > xxx-123 and key <xxx-332" and now it works.
In my opinion this is an issue in JIRA tool. Not existing issue should not be a reason for search failure.
If someone will remove issue xxx-332 i will have the same problem again. :(
Br, Natalia
