Linked issue not show in jira application mobile
Nicolas Andika
Dear all,
when i want to create issue in jira applications mobile, the linked issue field is not appear in the screen, but when i create the issue in the jira cloud web, the linked issue in appear in the create screen and when i view the issue in jira applications mobile, the linked issue is appear, how to solve that problem?
Thankyou
Lucas Modzelewski _Lumo_
To link issues on mobile app (android), you can use the options menu in the top right corner.
When linked issues are added, then Linked issues section will be visible under issues, with option to link other issues
Nicolas Andika
Hi @Lucas Modzelewski _Lumo_
Thanks for the answer, it works when the issue already created. What if i want to link issue when i create the issue, not after the issue is created, because i set validator in the workflows to link the issue, but there is no linked issue in the create screen WhatsApp Image 2024-10-07 at 14.02.26.jpeg
Thankyou
Looks like a missing feature, I tried to add link on transition on separate screen and it is also not possible :(
I've made it required and it is being ignored on mobile :(
Nicolas Andika
yeahh :( do you know where can i raise this issue?
To help us get the right details and fix bugs as quickly as possible, submit your bug report in our support system.
You can still view, watch, comment on, and vote for existing bugs.
I tried to search for existing bug report on this, but nothing interesting shows up. And mobile apps is missing the project ;/
If you get the link to the public ticket, let us know - for sure I'll give it a vote ;)
In the meantime you can access Jira on mobile browser in desktop mode to get all the features.
