Low Work without time spent
Fredrik Ivansson Flinta
Hi all,
Does anyone know if it is possible to use the "log work" without Time Spent information?
I'm would like to have a simple "progress information/logger" but i'm not interested in loggin time.
Using comments is not a option since comments are and shall be used for comments.
Jack Brickey
could you articulate a bit more one your requirements? What constitutes logging work for you? A simple "hey I worked on this" tick box or some text or some automatic clock or....?
Progress information could be:
First entry: Today i corrected hey.c lines 33-34 (<DATE AND TIMESTAMP> <USERID>
Second entry: Now also lines 35-36 is corrected (<DATE AND TIMESTAMP> <USERID>
Jack Brickey
So you will need to do that in the Comments I think. While you could use a multi-line text and simply add to the top IMO that is a bad solution and you might run out of space. Of course you could also you the time logging feature and simply put in some bogus number e.g. 5m and leverage the comment area for the details. In fact that is the best option IMO.
Thanks, but i dont want to mix Comments and this kind of information.
Insert some bogus numbers was my inital idea before posting here, but that confirms that so I might go for it :)
Pramodh M
Hi @Fredrik Ivansson Flinta
Add Multiline text field in the transition and have field required!
This will surely achieve your requirement.
Pramodh
Pramodh M
FYI,
Only add the fields you require in the transition screen.
Comment will be shown by default.
Thanks, but edit is the most common action that is used when adding the information.
And a multiline will not work since there will be multiple edits/logging in each issue.
SERVER
VERSION
8.5.3
