(MAC) Jira had problems starting up: system plugins failed
Sorin Marin
February 16, 2019
I'm trying to set Jira to work on localhost:8080
I get this message:
System plugins failed to start: We haven't been able to start all the required system plugins
We couldn't start the following plugins:
  • com.atlassian.jira.jira-quick-edit-plugin (com.atlassian.jira.jira-quick-edit-plugin)
  • com.atlassian.jira.lookandfeel (com.atlassian.jira.lookandfeel)
Did anyone encounter the same issue? Will appreciate any help!
Krisztian Kovacs
February 27, 2019
hi @Sorin Marin
had the exact same message and switching java from openjdk to java8 solved the problem.
see how-to here: https://stackoverflow.com/questions/21964709/how-to-set-or-change-the-default-java-jdk-version-on-os-x
let me know if this helped
Praveen Manakattil
March 28, 2019
Hi, am facing the same problem anyone can help on this please??
Krisztian Kovacs
March 29, 2019
My only idea at this point is to check whether you're using java8 or something else. If you're using java 7, Jira will let you know but in case of openjdk, it won't.
Let me know if that helps.
Nelia Namur
March 14, 2019
Hi, I am having the same problem. What do I need to do? I have read the stackoverflow site, but still don't know what to do? Can anyone help? This is my first Jira Server installation.
thanks
Krisztian Kovacs
March 29, 2019
For me the problem was that by default my computer had openjdk instead oracle's java 1.8.
Once I set Java 8 everything worked.
