Hello All,
Is it possible when an issue ( from any state ) is moved by an user from Project X to Project Y ( user is not member of this project Y ) then the users in particular role in Project Y will get the email notification of the moved issue ?
Kindly provide your approach regarding this problem.
Thanks in advance.
Best Regards,
Tanu Ranjan Bharadwaj
Hello @Tanu Ranjan Bharadwaj
Please see here as to how issue move notifications works
https://community.atlassian.com/t5/Jira-questions/Notifications-Issue-Moved/qaq-p/1042933
For the issue move event in the project Y you can add the relevent users in a role and add that role in the notification scheme for the project Y issue move event and thus they should receive the notifications.
Hello @Tarun Sapra ,
Actually the requirement is that if A user moves an issue from a particular state from Project X to some Project Y then particular role will get the mail notification in Project Y ( condition is here that A user which is from project X is not the member of Project Y) and the roles depend from which state the A user is making the Move operation from Project X to Project Y.
For Ex.
From Project X--> State: In Progress then In Project Y--> Developers Role will get the notification, and just like that if
From Project X--> State: Fixed then In Project Y--> Testers Role will get the notification regarding the move operation that this issue from project X is moved to their project from State Fixed ( from Project X).
Do you know anything regarding this ?
Thanks in Advance.
Best regards,
Since by default issue move notification is independent of the workflow status of the issue in source project hence there is no out of the box way to implement what you want.
What you can do is write a custom listener which listens to the issue move event and then based on the workflow status of the issue sends out email to the users in a particular role in the project.
Could you help me with the coding part of it because I want exactly what you have mentioned in your current.
Thanks in advance.
Best Regards,
Can you help me with its coding part ?
Thanks in advance.
Best Regards,
