Making a closed issue read only
JasonD July 31, 2014
I have a custom workflow, when I transition to closed status and give it a resolution (fixed), I expected the issue to become read only (ie. the edit button would disappear). However it is still editable. Is there some post function I am missing? Anyone know the secret sauce?
Thx.
4 votes
Nic Brough -Adaptavist-
July 31, 2014
There's a workflow property you add to steps where you want to stop edits.
I can't do it from memory, but open up the JIra default workflow and look at the "closed" step's "properties". You'll find it is used there.
JasonD August 11, 2014
Thx!
For future reference:
add the property:
jira.issue.editable
and set it's value to false
Like # people like this
Lotus Support July 25, 2017
How to disable creating sub-task on closed parrent issue?
