Is it possible to manage/add to the Watchers list when creating an issue? I would find it very helpful to assign the ticket to a user and then add Watchers in the create issue step.
David
Hey,
these are the first Google results:
https://jira.atlassian.com/browse/JRA-5493
https://jira.atlassian.com/browse/JRA-2167
http://justinit.wordpress.com/2010/12/17/jira-add-watchers-at-issue-creation/
Cheers
Christian
So... right now...this is not possible without plugin?
You can use the Post transition functions to add a watcher as part of the workflow. (Just make sure you put the field update after the ticket creation). It doesn't provide the versatility that I would have liked, but it solves my present problem.
https://marketplace.atlassian.com/plugins/com.atlassian.jira.plugin.workflow.jira-watcher-field
Works great: you can add watchers on create, or change them on edit. (And if you want to change them before Commenting, do edit but don't change any fields)
