Migrate Confluence spaces and fix links
Anuradha Yadav October 6, 2022
Hi Team,
We have 2 server instances server A and Server B.
Jira project already migrated to Server B Jira, yet we see plenty of links are still pointing to Server A Jira.
Could anyone please help with what things we need to check/address to fix this?
Anu
Fabio Racobaldo _Herzum_
Hi @Anuradha Yadav ,
how did u perform that migration? If you used a standard approach, all link should be automatically adapted using the base URL of Server B.
If you are talking about links in comments/descriptions you need to update them through the DB.
Fabio
Anuradha October 12, 2022
Hi @Fabio Racobaldo _Herzum_ ,
Thanks for you response. The Migration has happened some how by a person who has left our team now, but now we see that Links in Jira project (SAART) which is gone through migration has many several duplicates which is pointing to old Jira project (SAARTD) in Issue Links.
Example below:
Is there any way that we can check only duplicates and remove them only?
or I was checking on some plugin which may help me to do this?
Find Duplicates  does this plugin has some solution ?
Anuradha
Anuradha October 13, 2022
Any update on this?
Is it possible to find Duplicate in Issue Links?
Anuradha
