Hi Team,
How to migrate from existing Project template to newly created project template.
Actually , I have one global project template, I need to migrate existing projects or project template to global project template,
Same configurations should reflect in Global Project also & they would be any data loss.
What would be the best way to do this without any scripting?
Thank You.
Hi @Sravani Battu , you cannot migrate a project to a different template. You can modify your existing project to mirror the desired template or configuration. How much work this would be depends entirely upon where you're starting and where you're going.
Hi Jack ,
How can I modify existing project template without effecting other projects.
@Jack Brickey Good afternoon. Just want re-confirmation. I have a project template -software Kanban board and I am thinking to migrate to Service Management project template. Based on your answer you can't migrate it. I need to create the project template from scratch? And make the old project template as a static page for reference. Please let me know. Thank you.
