For some reason, suddenly the options from left panel are missing for the projects which were present earlier like "reports" , "release".
How can we fix that. Has any one encountered this issue.
Hi Rashmi,
For options (in left Project panel) like "Releases" you need Project Administrator permission. If you can't see any option in left panel, its possible you see only Board (Shared Board between Jira projects).
I need for some more info about your problem.
Thank you
Pavel
Identified the issue, for my environment it was one of the scripts that malfunctioned and resulted in this issue.
