Move custom field to custom web panel
Mark Fallaize December 24, 2020
I saw this question was raised in 2014 with no answer: https://community.atlassian.com/t5/Answers-Developer-Questions/Move-custom-field-to-custom-web-panel/qaq-p/503199
Does anyone now know how to do this? Currently certain custom fields are displayed in both the detail view and a custom panel, but we just need them in the custom panel...
Regards
Mark
Ravi Sagar _Sparxsys_
December 24, 2020
If you have ScriptRunner or willing to write your own app then you can get close to what you are looking for.
Check this page to get some ideas https://community.atlassian.com/t5/Jira-Software-questions/Add-an-editable-field-as-web-panel-with-ScriptRunner/qaq-p/1371110
I hope it helps.
Ravi
Hi Ravi,
Thank you for you reply.
Actually, I used this link to get the field in the panel. But how can it be removed from the details panel so that it only shows in the custom panel?
Regards
Mark
December 24, 2020
Remove it from the view screen and only keep it on edit one.
Mark Fallaize December 29, 2020
As simple as that, thanks!
any way October 27, 2021
1、in the jira-view-issue-plugin ,add a customfield-panel
2、delete the customfield from  the createCFTabs DetailsBlockContextProvider in the source code
