Moving to another project display default "Issue Status" as Cancelled
Sarabjeet Singh
July 3, 2019
When I move to another project, Default status is "Cancelled" and then I have to change to "In progress" everyone. Can Admin change the default status for moving to this project ?
Nic Brough -Adaptavist-
July 3, 2019
It's simply picking the first status it finds.  You can't change it directly, from memory, it's based on the id of the status - first one it finds in the workflow gets used.
[Deprecated] Nick Spreitzer December 20, 2021
The step IDs correspond to the order in which the step itself was added to the workflow. In my case "Done" had the lowest ID in the workflow, so I deleted and re-added it, which resulted in it having the largest ID in the workflow. Hence, it appeared last in the list of possible statuses during the move issue wizard instead of first. So this is fixable, although it's a bit of a pain.
December 20, 2021
Mmm, not quite.
The step ids correspond to the order in which the steps were added.  Globally though, not to each workflow. You could end up with your "fix" not working, if you've got more than one admin tinkering with workflows at the same time.
It's unlikely to happen, I am being pedantic, but I just wanted to note that it could still do unexpected things in some cases.
[Deprecated] Nick Spreitzer December 21, 2021
My experience doesn't exactly align with your statements. When I deleted and re-added a step from one workflow, then proceeded to another workflow, the latter workflow was unaffected by the change to the former workflow.
Dave Furlani
August 14, 2023
I suspect this relates to this request, which needs more community support to bubble to the top of the backlog - https://jira.atlassian.com/browse/JRACLOUD-39752
