Good Morning Folks
I would like to know what would be the best option or way to create multi levels/cascade fields with conditions, for example i have a product and this product, i choose a product from list and based on the product list to me number of contracts a observation is a product may have 1 or N contracts numbers.. another example would be i choose a country and only list me the country states and then only the states of that country e continuos to citys..neighbhood etc..
Ty for any advices
ps: im trying to solve this using dynamic forms, table grid and some anothers plugins
Hi @Marco Augusto Santinho Gonçalves I will Give a simple suggestion if it works for you you can try
For me i have a cascade fields Field called "Business"
OK in the If you select the "Country" option on right side dropdown box i have added the values like "NA, ASPC, Canada, SA, etc.,"
Now i Have the multi-select custom field like NA States added all the states
Now I wrote a Behaviour script Now when i'm creating a ticket choose the Cascading field field value "Country, NA" It will show the Multi Select Field called "NA States" in that I will Choose one or more States.
Same like that you can do for rest of the options
This is one way we can do
I hope its works
Phani
HI @Marco Augusto Santinho Gonçalves Here is test script work around
// customfield_10001 -- cascading field
// customfield_10002 -- multi Selectlist field
// United States -- Value from Right side dropdown menu from cascading field
Note: Please make sure the "United Satates" Value is not repeated value in parent Values
if(getFieldById("customfield_10001").getValue().contains("United States")){
getFieldById("customfield_10002").setHidden(false)
getFieldById("customfield_10002").setRequired(true)
}else{
getFieldById("customfield_10002").setFormValue(null)
getFieldById("customfield_10002").setRequired(false)
getFieldById("customfield_10002").setHidden(true)
I hope it helps
Phani
