Dear community ,
We are setting up Jira Service Desk (Latest version 7.13.0) .
We have filed
1) Issue Type ,
2) Category
3)Component
4) Organisation
5)Queue Name .
We have a requirement like when an Issue type is selected based on the issue type the respective " Component , Category , Organisation and Queue Name " fields should update automatically .
Can somebody help me and give me the suggestion for this .
Please let me know if there is any addon available for this kind of multi level cascading select for Jira Service Desk 7.13.0.
Sham
The Table grid editor for server app has a multi level cascade where the drop down lists can made dependent on issue values. It is service desk compatible
Check out some examples here
Francis
(PS. I'm with the team that builds this app)
hi Francis,
Greetings for the day.
Thanks for your reply .
I have installed Table grid editor in my JSD with evaluation license and exploring it but not able to understand .
I dont know scripting . Please help me in setting the below example
here the requirement is like this :
there are three filed for multi level cascading 1) Organisation 2) Component and 3)Category.
" Organisation " field contains values : Org1 , Org2
" Component " field contains contains : Comp11, comp12 , comp13 , comp21 , comp22 , comp23
"Category " : field contains : cat11 , cat12 , cat13 , cat21,cat22 ,cat23
when I select Org1 in Organisation filed
the component filed should populate comp11 comp12 comp13 and
Category filed should populate : cat11 , cat12 , cat13
when I select Org2 in Organisation filed
the component filed should populate comp21 comp22 comp23 and
Category filed should populate : cat21 , cat22 , cat23
Please help me in doing this.
Sham
You would need an add-on for it. For example, you could use the Power Scripts add-on:
You create a live field to set correct values for issues.
You can find an example here:
https://confluence.cprime.io/display/TR/Create+custom+cascading+select+field
Live fields only work in the Jira UI. It does not work in Portal.
If you need a solution for Portal you could use other add-ons like ScriptRunner or Extension for Service Desk.
hi Alex,
is there any way or other addon where I can get a multi level select options in a single row .
for the filed 1)component 2) organisation 3) category 4) queue name in a single row .
All the 4 fields should appear in a single row as a multi level select
