I wish to have different Issue Layouts (different fields displayed) in the Project settings for two different Issue types:
I can only see an option to Edit issue layout for both together (as defined by the WG - SD and C Screen).
Is there a way to Edit issue layout for different Issue types (eg Change Request) (as defined in Another Screen)? SEE MY PIC.
I have tried:
Hi @Gavin Klose ,
It seems that both CAb and Change request use same screen scheme "WS- SD and C Screen" base on your screenshot. You may create different screen scheme per issue type so you may align differemt layout of your issuetype.
Yes, I found out how to add the different screen schemes via the Issue Type Screen Scheme. Not intuitive but I got there.
