My JIRA index is newer than database - how to fix?
Chad@ Norwood
My jira failed a health check, and says the following under "Indexing Lucene" on this page: JIRA.EXAMPLE.COM/plugins/servlet/troubleshooting/view/?source=notification
"The issue index is inconsistent with the database state. The last issue update recorded in the database was at (10/27/17 9:10 AM) but the last issue update recorded in the index was at (10/30/17 11:59 AM).
In other words, the database has old data, the Lucene index has newer data.
Note this was probably a result of database port being blocked.
How do i force database to update from jira index?
I have jira 7.5.1 and postgres 9.4 all running on linux, one host.
Andy Heinzer
November 1, 2017
There is no process to take index data and move it to the database.  Database data and Index data is not a two-way street, so to speak.   The indexes are created solely upon the content in the database.
When you update/create issues in Jira, the database is actually being updated first, and then Jira is triggering an incremental index update to grab that new value and add it to your existing indexes.   Jira does not source data from the indexes to be then placed into the database.
It is unusual that the indexes would state their update is newer than the database, I grant you that.  Usually when we see this health check warning in support, it is the other way around, with the indexes being significantly older than the database.  Which usually indicates that the indexes are corrupted and in turn have to be rebuilt from scratch.
Since you mentioned there was a blocked port to the database, I think it more than reasonable that the healthcheck Jira is running was simply unable to update this value which in turn is generating this error.
I am curious to see if perhaps just restarting Jira can kickstart this healthcheck into being able to reestablish this check correctly once more.  If that doesn't work, then recreating the indexes is another valid means to troubleshoot this as Alexey suggested.   I wouldn't expect this problem to happen again, unless there is something preventing Jira from reaching that database periodically.
Alexey Matveev
October 30, 2017
You need to reindex Jira. More about reindexing you can read here
https://confluence.atlassian.com/adminjiraserver071/search-indexing-802593000.html
Chad@ Norwood
Re-indexing copies from database to Lucene, which erases all information in index.
I wanted to copy from index to database.
Andy Heinzer
October 30, 2017
Chad@ Norwood
Thanks Andrew - your comment is the best "solution".
I resolved to lose my changes that weren't in database by doing a reindex (which i've done hundreds of times).  That still created a problem since the index had more issues than the db, but after jira reboot there were no more problems reported by jira.
Andy Heinzer
November 1, 2017
HI Chad,
Thanks for letting me know.  I will re-post my previous reply as an answer and accept it in case other users encounter this same kind of problem.
Andy
Brian Jones
Are you running on the same machine? If not, make sure you have NTP running and they are pointed at the same time source. That could be a cause.
Chad@ Norwood
For others this is something to consider, but not applicable in my case.
