My Jira Tasks that are done do not appear in Burndown Chart
jinali-p April 24, 2020
Hi There
Need help. Started a sprint and some tasks have been completed within an Epic, but not all. Looking at the current burndown it does not reflect what has been completed, although it shows, what was committed to the sprint and added (scope Change). Using story points to estimate.
Please help.
Jack Brickey
Hi @jinali-p , welcome to the Community. Please verify that these “Done” issue actually have the “Resolution” field set and are not listed as “Unresolved”.
@Jack BrickeyThank you for the reply. How do i find this field? The workflow is fine.
Cheers
Jack Brickey
If you are on Cloud (your url would be something like xxx.atlassian.net) then when you look at an issue in the detail view you would see something like below. you can also go to you sprint report and click on view in navigator and add the Resolution Column.
@Jack Brickeyhere is where i should see my done items, which defo have been completed during the sprint....
Nic Brough -Adaptavist-
April 26, 2020
Are they in the last column on the board?
Like jinali-p likes this
jinali-p May 19, 2020
apologies for the dely but thanks this was the issue :)
