My interface doesn't have a More field.
anil.katta April 4, 2024
Hi Team,
More field is missing in my interface. Attached screenshots
Zoey Wang
Hi @anil.katta
You might wanna check the Configuration of this issue type i.e. point 5 in your first image. Under Hide when empty section, there seem to be no fields being listed yet. That explains no More section in the issue view. Once you try to put a few more fields in the section, the "missing" part will show up.
Thanks Much, i can see the more filed section now
Zoey Wang
Hi @anil.katta
If this helps please consider Accept Answer, other users with similar questions will easily find the solution. Thanks
