×NEED IMMEDIATE ASSISTANCE! JIRA Software not working due to JIRA Core trial expiration. Please call <private info removed by Atlassian>. Thanks.
We're a bunch of customers(like you). There are some Atlassians here but we're not support.atlassian.com.
You can:
We already had JIRA Software & JIRA Service Desk. We then added a JIRA Core trial. However, I think we already had that product as part of the other products. Is that true? If so, JIRA should not allow you to start a JIRA Core trail (and subsequent purchase) if already included.
BTW, I resolved my problem by simply removing the JIRA Core trail---we can now add JIRA Software & JIRA Service Desk tickets.
Hi Scott,
I'm happy to hear that. If you add other products and one of the licenses expire you'll run into issues like that so that's something to be aware of in the future. For more information on the difference between the two see JIRA Software vs. JIRA Core: License.
In regards to JIRA Core existing with the other products, I can definitely see the confusion if Core is installed alongside Software since it's already included as part of JIRA Software.
In light of that I would suggest creating a Suggestion on JAC. This will get the issue in front of our developers and they will either provide an explanation as to why this is allowed in the same instance or change it so this is not possible.
If you do create a Suggestion ticekt on JAC please link it here so the community can find it and vote on it!
Branden
Ah, you may not need Core at all.
Core provides a whole pile of stuff - issues, users, the add-on framework, workflows, screens, fields and so-on.
Service Desk and Software run on top of Core and add more functions. They can't run without it because they rely on the Core issues, workflows etc. Any user who is licenced for SD or Software is using Core and has access to Core.
But, it lets you trial Core because you may well have a need for three sets of users - Core, Software (inc Core) and Agents (inc Core)
HI Scott,
A couple things here:
Branden
Interesting, I selected "Contact Support".
It appears JIRA Core is not needed if you already have JIRA Software. Is that correct? I believe we unecessarily started a JIRA Core trial and when the trial expired, we could no longer add tickets to our existing JIRA Software tickets.
