Need Automation solution for below example?
Sabarish
April 22, 2024
Status and Effort at Feature Level
Feature
Status
Hours
Feature 1
To Do
40
Feature 2
Done
30
Feature 3
In Progress
60
Feature 4
Done
80
Feature 5
Done
40
Feature 6
In Progress
50
300
Following should be the result of the automation: -
Summary at Epic Level
Status
Total Hours
To Do
40
13%
In Progress
110
37%
Done
150
50%
Y Dang_Candylio
April 22, 2024
Hi @Sabarish
I think you could use the Dashboards instead. There's a gadget which is called Pie Chart.
In this gadget, you can configure the filter which query the Epic and choose to show the status by percentage. It will be updated automatically by the real time.CHnj3H2G8M.pngI hope this helps!
Sabarish
April 22, 2024
Thank you, yes this would surely help. Also need to update the story estimates to the epic through automation. whenever new story is created or completed it to auto update estimates in epic level.
Y Dang_Candylio
April 22, 2024
Hi @Sabarish
You can create an automation rule like this. Whenever an issue transition to Done, it will check the Epic of this issue. If the Epic is To Do or In Progress, it will be automatically transitioned to Done.
Hope this helps!
