Hi Team,
Here I'm creating a script fields
> The total Time Status in Particular Status. here is the script Can any one help in my script that its calcualting the Milleseconds I need like proper Time Format and days.
import com.atlassian.jira.issue.history.ChangeItemBean
def changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
def inProgressName = "X"
List<Long> rt = [0L]
def changeItems = changeHistoryManager.getChangeItemsForField(issue, "status")
changeItems.reverse().each { ChangeItemBean item ->
def timeDiff = System.currentTimeMillis() - item.created.getTime()
if (item.fromString == inProgressName) {
rt << -timeDiff
if (item.toString == inProgressName) {
rt << timeDiff
def total = rt.sum() as Long
return (total / 1000 ) as long ?: 0L
Its counting in total seconds
Is there any chance to count if the ticket is been in that status like 7 days in that particular ticket so that i can add that in column report.
can any one suggest me please.
thanks,
Kumar
You should simply need to modify the in the last line of your code that is converting milliseconds (the original format you get) to seconds so that it is converting milliseconds to days. For example, the 1000 you're currently using is because there are 1000 milliseconds in a second. You need to get milliseconds in a day. If you do the time calculations (or look it up), you can find that there are 86400000 milliseconds in one day. Thus, to get days from this you need to change the last line of your script to 'total/86400000'.
Hopefully this helps! Let me know if you have any other questions.
Jenna
Hi @Jenna Davis Thanks for your response
It worked it calculate days i'm asking like format like
"07days | 02:30m "
Like kind of format if I want how can I modify this can you help me or if i want to know
When I Open any issue if want to know how many days since its been in that status need to know do i need to create each status script field ???
Kumar
Okay, I think this community post might help you out:
https://community.atlassian.com/t5/Marketplace-Apps-questions/Age-of-the-Issue/qaq-p/275028
In short, try using 'DateUtils.getDurationString()' method. That post shows you what is needed in a bit more detail.
Jenna
Hi @Jenna Davis thanks for your reply
I just need to know the total days and Time spent on particular status on each issue.
Example:
On "X" status the issue is been like 1d 2h 30m
like on each status how much time spent a user i need to know
the link you shared is calculating an total issue time that will help me in one but now i'm looking like on each status how much time it spent
Kumar
You should be able to do this using the example in the link I sent, you just need to modify the code a bit based on what you want to get.
For example:
DateUtils.getDurationString((total / 1000) as Long)
Does this make sense?
If you're getting back something different that what you expect when you try this could you please let me know what template you're using and what exactly gets displayed?
Jenna
Hi @Jenna Davis Thanks for your help it worked
here is the Final script
import com.atlassian.core.util.DateUtils
def inProgressName = "X" // put status that you want
rt << -timeDiff
rt << timeDiff
return DateUtils.getDurationString ((total / 1000) as Long) ?: 0t
Kumar
Hi @Jenna Davis
If I want get the "assignee" info in those status how can i modify the script
can you help me please with the above script that it also need to pull the "Assignee" in those particular status.
Kumar
