NS board - Agile Board - JIRA
TypeError: Object.keys: argument is not an Object
at b.forEach (http://usvfre105:8080/s/c35ce271647315092bcadba5a348400e-CDN/-g9cne0/75007/b6b48b2829824b869586ac216d119363/aa6cf545ff213915ecbf1d6cdcbaa2cc/_/download/contextbatch/js/_super/batch.js
Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; rv:11.0) like Gecko
This kind of JavaScript error is known to be caused by any of the following:
In order for us to troubleshoot this further, could you please try to answer the following:
select * from fieldconfigscheme where description like '%<script%' OR description like '%<SCRIPT%'; select * from customfield where description like '%<script%' OR description like '%<SCRIPT%'; select * from customfield where description like '039avascript%' OR description like '%html%' OR description like '%css%'; select * from fieldconfiguration where description like '039avascript%' OR description like '%html%' OR description like '%css%';
Hello
I'm facing the same issue here.
The Error occurs when i'm moving a Jira Subtask from "in progress" to "resolved".
This happens in ie 11 (11.0.9600.18921).
Chrome works just fine.
Best Regards
Manuel
Hi Manuel,
This is a bug Atlassian will have to fix. What version are you using? The bug seems to be affecting 7.5+.
You can vote/watch this issue:
https://jira.atlassian.com/browse/JSWSERVER-16177
Maxime
Ben,
Can you tell us exactly what you were doing to cause the error, and which browsers you're able to replicate this in?
Shannon
