×Hi,
Can you please provide me a groovy script for sum of two fields that display results in third field. I have tried using JCMF but it is not working as expected.
1. Cost1 - Selectlist single choice (1-5)
2. Cost2 - select list singlechoice (1-5)
3. Total - Scripted field Cost1+cost2
Any help would be much appreciated.
Ravi
Hi @Ravi there is similar thread: https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Calculate-the-value-of-two-single-select-custom-fields-that-have/qaq-p/1115641.
You just need to adjust custom fields names and to change multiplying to addition in the script of @Milan Chheda [INFOSYSTA]
Try to use this code:
def costValueStr = issue.getCustomFieldValue(cost)?.getValue()
def selfValueStr = issue.getCustomFieldValue(selffinance)?.getValue()
if(!costValueStr || !selfValueStr){
log.error("Invalid values [costValue:{}, selfValue:{}]", costValueStr, selfValueStr)
def costValue = Double.parseDouble(costValueStr)
def selfValue = Double.parseDouble(selfValueStr)
return costValue + selfValue;
Hi @Ravi , not sure if this helps.
But here's my sample Listener code on calculating 2 custom field's value:
def issueManager = ComponentAccessor.issueManager
def v1 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("value1")
def v2 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("value2")
// your issue key heredef issue = issueManager.getIssueByCurrentKey("TESTING-1")
// convert the value to int
def i = (issue.getCustomFieldValue(v1) ?: 0)
def j = (issue.getCustomFieldValue(v2) ?: 0)
return (i ?: 0) + (j ?: 0)
Thank you but I get the following error, when I use the script in scripted field.
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.customfields.option.LazyLoadedOption.plus() is applicable for argument types: (com.atlassian.jira.issue.customfields.option.LazyLoadedOption) values: [5] Possible solutions: use([Ljava.lang.Object;), is(java.lang.Object), split(groovy.lang.Closure), wait(), dump(), grep() at Script108.run(Script108.groovy:9)
Ravi
@Ravi you cannot use value of the field directly as it is "Option" and its value is of "String" type. I posted you a part of the script in my first thread which should fix your script.
Here is my code
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.comments.CommentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.plugin.webfragment.model.JiraHelper;
def customfieldManager = ComponentAccessor.getCustomFieldManager()
def cost = customfieldManager.getCustomFieldObjectByName("Cost");
def selffinance = customfieldManager.getCustomFieldObjectByName("SelfFinance");
def costValue = issue.getCustomFieldValue(cost) as Double
def selfValue = issue.getCustomFieldValue(selffinance) as Double
if(costValue > 0 && selfValue > 0) {
} else {
return null;
I get the following error.
2021-01-28 13:58:16,390 ERROR [customfield.GroovyCustomField]: ************************************************************************************* 2021-01-28 13:58:16,391 ERROR [customfield.GroovyCustomField]: Script field failed on issue: GMOPMR-523, field: Total org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object '2' with class 'com.atlassian.jira.issue.customfields.option.LazyLoadedOption' to class 'java.lang.Double' at Script88.run(Script88.groovy:14)
Does it rely on the custom field type?
Ravi
