Need assistance with Jira Cloud Automation
RNV Jira1 May 30, 2022
Hi All,
I am new to Jira automation and i have the requirement of to complete the following -
We 4 Numeric value custom fields in Jira cloud and i need help with creating an automation rule to get the highest value of the first 3 fields to be populated on the 4th field.
Example:
Field 1 - Drop down values 1,2,3,4,5
Selected value - 4
Field 2 - Drop down values 1,2,3,4,5
Selected value - 1
Field 3 - Drop down values 1,2,3,4,5
Selected value - 5
Field 4 - Drop down values 1,2,3,4,5
Need the value of "Field 3"  which is 5, as that is the highest value from the above 3 fields
Any guidance here will be very helpful, thank you in advance
3 votes
Alex Koxaras -Relational-
Hi @RNV Jira1 and welcome to the community!
Try the following, it worked for me:
  • Create a rule
  • Add as trigger "Field Value Change" and select all numeric fields you want to this rule to get triggered
  • Create a variable with a name "maxValue" and enter
    {{#=}}max({{issue.fields.NumSel1}},{{issue.fields.NumSel2}},{{issue.fields.NumSel3}}){{/}}
  • Add a new action to edit the last single select field you want
  • Add the {{maxValue}} variable you created
Alex
RNV Jira1 May 31, 2022
Hello Alex,
Thank you for the quick reply, this worked as expected and we are getting the required values. Thanks again
Have a good day
Good to know that this helped you!
Karyna Tyrnavska _SaaSJet
Hi, @RNV Jira1
Another solution, you can check if you're comfortable with Marketplace plugins, is Business Process Manager add-on, developed by my team.
For solving your case use Form Logic with if/then rules. Here is an example:
Vikrant Yadav
Hi @RNV Jira1  Welcome to Atlassian Community!
Are these (Field 1, Field 2, Field 3 and Field 4) number fields or single select list fields?
V.Y
