Need help for incorrect workflow for Epics Requirement Review/Sign Off issue
Tien Nguyen November 25, 2021
The workflow for Epic Requirement Review/Sign off should be the Simple Sign Off Workflow, not the Exploration.
The configuration is correct, but the workflow is falsely displayed on JIRA2.png1.png
Sandesh Shetty
November 25, 2021
@Tien Nguyen
It seems workflow changes are in Draft state. You need to publish that, then only changes will reflect.
Hi @Sandesh Shetty
We did it. Thank you so much!
Regards
