×Hi All,
I am migrating all the issues from next gen to classic in the step 3 what do I need to do if I want to retain the same epic names after the migration?
I have another issue if I try to bypass this with some names, I see removed fields in the final step before the confirmation, I don't want to loose any data in the process of migration(attachments and Comments or any other).
Please help me with the steps I need to take care of retaining all the information.
Krishna
1. You should try first on a test project. I believe that you will not loose attachments and comments. These are just count fields
2. You can later update the fields for epics either manually or programmatically.
You are most welcome!
