Need help in upgrading the jira,bitbucket,crucible and crowd instance
ramani_chandran
we are about to upgrade the below applications. Kindly anyone provide the latest enterprise versions for the below ones to upgrade.
current versions:
Jira Server 7.1.2
Bitbucket Server 4.4.1
Crucible/Fisheye Server 4.0.3
Crowd Server 2.8.4
PVS
Banned
October 14, 2019
ramani_chandran
Hi @PVS  ,
Can you please provide the specific enterprise version for all the applications to upgrade. Since the provided url has only the compatibilty details.
Thanks.
PVS
Banned
October 14, 2019
@ramani_chandran    Tell me one thing Firstly Which Version You Want For Jira
ramani_chandran
@PVS  ,
 i want to upgrade to the latest version available. I can see 8.4 is the latest one for jira. But it is mentioned like its end of life is Sep 2021. But if i upgrade now that should last for minimum 3 years. Since more applications are residing in our servers,frequent upgrade is not possible. Kindly suggest an idea.
PVS
Banned
October 14, 2019
Hi @ramani_chandran
Do one thing check the 8.0 Matrix And You Will Upgrade to that verssion Dont Upgrade the directy 8.4 i think 8.0 Is Suffissient For you
PVS
<iframe></iframe>
ramani_chandran
Hi @PVS  ,
Thank you. while i was looking for upgrade matrix 8.0....Its also mentioned like the enterprise version 8.5 will be released soon . can i go for it?
PVS
Banned
October 14, 2019
Hi @ramani_chandran
Don't Go The Releasing Versions  Because Of releasing versions are facing some problems (Bugs) after 1 2or 3 months you will go to update the 8.5 That Is good for Upgrade
ramani_chandran
ok thanks
PVS
Banned
October 15, 2019
ok
PVS
Banned
October 14, 2019
